B&M Trick Shift ATF
Old May 12, 2012 | 08:57 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
B&M Trick Shift ATF
SHould it bee used in a 700r4 or should i stick with dex
Old May 12, 2012 | 09:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: B&M Trick Shift ATF
Waste of money, use the Dexron.
Old May 12, 2012 | 09:25 PM
Engine: 305 LO3
care to explain
Old May 12, 2012 | 09:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's Ford Type-F fluid with blue dye.
Old May 12, 2012 | 09:28 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
It's cheaper?
Old May 12, 2012 | 09:31 PM
Engine: 305 LO3
has it caused any problems before?
Old May 17, 2012 | 07:43 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
It's a waste of time, use Dextron and some Lucas conditioner with the fluid change, it helps renew old seals and cleansup valves, definitely helps an old transmission....
Old May 17, 2012 | 08:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Or better yet, straight Dexron with no snake-oils at all.
Old May 17, 2012 | 09:24 PM
It is some locally produced Type F by some local supplier (think "Coastal"... nothing "bad" or anything like that, just, nothing "special" either, just something completely utterly absolutely irrevocably "normal"...) with blue dye.
Marketing gimmick
If you're one of the sheeple, go for it. And put premium gas in your low-compression 305 while you're at it, after all the TV commercial showed at least one pretty girl. (I think?? maybe it was some other TV commercial, maybe it was octane booster, maybe it was some kind of spark plugs, I forget, buy em all........ )
If you're smarter than that, move on.
Since you've got enough sense to ask, I'm thinking you're one of the latter.
Old May 17, 2012 | 09:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The girl must have been on the gasolline commercial, 'cuz it was Chuck Yeager selling spark plugs, and Richard Petty pushing STP.
Old May 18, 2012 | 05:07 AM
J91's Avatar
J91
Have you ever tried Lucas in a high mile Tranny? It actually works, and is not a snake oil. I run a shop and have brought more than one old trans back from the edge w/it. Is it the proper fix, NO, but it will add some miles and durability. We aren't talking high performance apps here just daily drivers. Call it what you like but it does help.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
RS Reaper
Sep 27, 2015 07:04 PM
