axle question/ whats broken
Old May 14, 2012 | 05:27 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
first i have to admit that the axel is a part of my car that I've never had to mess with and thus my knowledge on the subject is limited
my car is a 1987 z28 model, factory five speed with a 3.23 gear set
cover plate on the axle says limited slip. from what I've been told and from what i understand its a "posi" axle. (that seems to be the word everyone likes to throw around)
my problem is that all of the sudden my passenger side tire is consistently the only one breaking loose, making traction even more hard to find
so what is it exactly that wares out and what needs to be done/ replaced to fix it?
Old May 14, 2012 | 07:58 PM
TNT_Z28's Avatar
Re: axle question/ whats broken
If I replace the posi unit, would it be worth going to the eaton offered on jegs or just replace it with another auborn. And what seals or bearings would need to be replaced as well?
Old May 14, 2012 | 11:58 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Eaton posi does seem to be a popular swap among
thirgenners here,but i don't know much about them.
I have a torsen waiting to go into mine to replace a
gov-lock that works like it is supposed to,but i don't
trust-especially don't care for the spider gear mesh on
the gov-lock...Carrier bearings can be difficult to
remove undamaged from the old carrier,so will likely
need new ones even if the old ones are still in good
shape-make sure to get timken or other high quality
brand.Could change the axle seals if wear or damage
evident,but i have never had any trouble with those.
Old May 15, 2012 | 09:23 PM
TNT_Z28's Avatar
what about adjusting for any sort of lash or alignment?
are there any tools or techniques that are required?
im not expecting this to be an easy un bolt, bolt in swap
Old May 16, 2012 | 10:20 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The easiest do-it-yourself fix still requires checking backlash before and after. Also need to keep the carrier shims in order, and even so, probably still need a good shim assortment. Your gears may also be worn, and this might be a good chance to upgrade. Got drums or discs? Want to keep the 3.23:1, or try something else? You may have some good options, depending on your answers.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
