Bum brand new hydraulics!!??
Old May 18, 2012 | 10:49 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I bought a new pre-filled pre-bled master/slave assembly off of Ebay for my T-56 swap. Everything was installed and ready to go, but when I went to test drive the car the clutch wouldn't disengage! That stupid plastic strap on the slave didn't even snap either! I tried bleeding the hydraulics, made sure the fork was in correctly, etc. I crawled under the dash today to double check the pedal linkage and saw that on the boot where the master rod goes into the master cylinder, that it looked a little wet. I pried the boot off and immediately fluid started running out. I'm very ticked of. I spent almost $200 on these hydraulics. Anyone else ever experience this?
Old May 18, 2012 | 11:30 PM
Engine: SBC 350
Re: Bum brand new hydraulics!!??
Now that I think about it, I think I may have been the cause for the failure. I'm pretty sure I hit the clutch with the strap off before the slave was installed. Can this blow the master cylinder?
Old May 19, 2012 | 08:12 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
That would break the slave not the master. If the master is leaking its defective or was damaged during install.
Old May 19, 2012 | 11:34 AM
Engine: SBC 350
The slave seems fine. I don't see any leaks and it moves in and out. I definitely did not break it during install.
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
