Moser rear gear oil level??
Old May 19, 2012 | 01:32 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm putting my car back together, and I topped off the trans fluid and figured I'd check the rear end oil level while I was under the thing. The pinion seal seemed to weep oil ever since I installed the rear, so I wanted to be sure the oil level was OK.
Boy was I suprised when I unscrewed the plug from the side of the housing! About 1/2 a quart of oil come flying out! These are filled to the bottom of the fill plug correct? - I mean, I normally fill it till oil starts to pour out of the hole, then I stick the plug in - correct?
Of course, I ended up not putting in a drop of oil after that much drained out...I'm wondering if that's been the issue with the pinion seal weeping oil since I've had the rear...will overfilling cause that?
Old May 19, 2012 | 02:13 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Moser rear gear oil level??
yes. fill just so it's at the fill plug. on the case housing. a bit more is ok, it works its way down the axl tubes anyway. (a bit more will be like a cup)
most of the time they ship them dry.
did they ship it filled?
some times fast lube Kids, over fill them by just pumping them. and yammering on to a buddy about there 5.0 rustang.
Old May 19, 2012 | 03:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
No, it was shipped dry...I have no idea how i could have put that much in...one of those mysteries I guess..lol
Maybe my pinion seal will quit weeping now. thx.
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
