Pressed my T56 pilot bearing in too far
Old May 20, 2012 | 06:02 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I tapped a little too much and the bearing is sitting inside the crank, exactly 0.070" past flush. I tried the grease method to no avail. Any advice?
Old May 20, 2012 | 06:10 PM
Re: Pressed my T56 pilot bearing in too far
Perfecly fine. Don't worry about it.
This one has ...... tens of thousands of miles on it; prolly over 60k.
Yes you are reading the block casting # correctly.
Old May 20, 2012 | 06:14 PM
Car: 89 GTA
Axle/Gears: 4.10
Cool thanks. How would you remove a bearing that's been pressed in too far? It seems the grease method wouldn't work well because there is no volume behind it anymore.
Old May 20, 2012 | 06:18 PM
Should work fine... doesn't require "volume" for any reason. That's the method I always use, hasn't failed me yet.
Old May 20, 2012 | 06:47 PM
Car: 89 GTA
Axle/Gears: 4.10
I didn't really mean volume, I just meant the grease needs to be able to get behind the bearing to push it out. If you press it all the way in there is no room behind the bearing for the grease to do its work.
Old May 21, 2012 | 12:33 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There is still room behind the bearing.
Personally, I'd use a two-jaw puller tool intended for the job. The outer race to the pilot tip of the maindrive shaft clearance is greater than that of a solid bronze bushing so you may have mixed results with the grease method.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
