91 700r4 reverse drum probelm
Old May 22, 2012 | 09:27 PM
b18c1355's Avatar
ok i have a 91 700r4 comes with a .095 reverse drum, i ordered a new reverse drum because the old one was too worn so the new one has a large sqaure hole. according to the atsg manuel the large sqaure hole drum will not work in a 91 700r4. only 93 and up ,and can retro fit early 82-87 but suposily the large sqaure hole drum will not work in late 87-92 acording to atsg manuel and i notice the 93 only has a added check ball for this large square hole drum. the place that sold me the drum said it will work in all 87 and up 700r4/4L60es. whos telling the truth here??
Old May 22, 2012 | 10:08 PM
morgsie's Avatar
Re: 91 700r4 reverse drum probelm
I just went through this with my build ('89 700R4). The drum with the square hole interchanges on +87 (possibly 82-86 as well) and is a better unit to use.
Old May 23, 2012 | 01:40 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if it has a checkball in the backside of the drum, it is the early '82-'86 model and has a different size piston. the '82-'86 also had a square hole. the '93 and up has the square hole and no checkball in the drum. these will retro all models if used with the piston that goes with them.
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
