T5 cluster support install.
Old Jun 5, 2012 | 06:27 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have a nice fresh rebuilt T5 sitting in my garage. I looked at the speedo gear inside and I have a red 9 tooth. I need the 7 tooth to go with my 3.73 rear end so I will be taking the tail housing off.
I was thinking while I was in there I might want to add a cluster support. Any idea how hard it is?
It looks like I need to take off one shift fork and a single snap ring, is that really it?
Do I need to measure any special clearances?
Old Jun 11, 2012 | 07:54 AM
midias's Avatar
Re: T5 cluster support install.
Anyone? Has anyone ever taken the T5 apart to the point where the cluster support can be replaced?
Old Jun 11, 2012 | 02:39 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
It is just under 5th gear. So if you have the tail housing off it isn't much work to take 5th gear off to get to the cluster plate.
Old Jun 11, 2012 | 02:44 PM
midias's Avatar
Yea I know there is 1 C clip and I need to remove the pin on the fork, but do I need any special measurement tools to put it back together?
Old Jun 11, 2012 | 02:49 PM
LilSki's Avatar
Car: 85 Trans Am
wouldn't hurt to have a dial indicator to check your counter shaft endplay but the new plate shouldn't really change anything. And in order to change endplay you would have to take the whole trans apart anyway.
Old Jun 11, 2012 | 02:53 PM
midias's Avatar
Awesome
Looks like I will need a
21 tooth gear 3987921
7 tooth gear 14071731
Sleeve 345215
cluster support
http://www.allstategear.com/BORG%20W...RT%20PLATE.htm
and finally the speedo gear clip.
Anyone know the clip part number I am having trouble finding it?
Old Mar 5, 2013 | 08:42 AM
midias's Avatar
Got this done last night. Went fairly smooth hopefully the end play did not get messed up changing from the plate to the support. Everything seemed to fit well I reused the shim that was there.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
