T56 Flywheel Question
Old Jun 5, 2012 | 01:50 PM
greeny's Avatar
Engine: Dart 427 SBC
Axle/Gears: Ford 9" 4.10
I have a 92 camaro RS with a 305. I just bought a T56 transmission and what to know if the new 92 305 is like the LT1. What type of flywheel, clutch and pilot bearing will I need to order?
Ive seen over forum with the old 2 piece rear main seal engine design but none with the new 1 piece.
Old Jun 5, 2012 | 02:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T56 Flywheel Question
86-up 305, 350, LT1 and LT4 all the way through the 2003 vans with 350 Vortec's all accept the same balance flexplate / flywheel. So if you have an LT1 T56, you can use an LT1 flywheel and clutch.
Old Jun 6, 2012 | 12:48 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I have an aluminum flywheel for sale. I decided to go with an automatic so I no longer need it. It's new still in the box just needs to be set up for neutral balance. All Summit listed were external balanced flywheels for a T56 when I bought it.
Old Jun 7, 2012 | 09:07 AM
Maroz2884's Avatar
Car: 1984 Z28 CAMARO
GET EVERY SINGLE PART FROM THE LT1 DONOR. YOU WILL NEED IT ALL EXCEPT PERHAPS THE PEDALS. YOUR CHOICE.
Old Jun 8, 2012 | 04:27 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
^^^what about a mid 70's 400....and what about balencing.
Old Jun 14, 2012 | 09:23 AM
Drifter92's Avatar
I have a brand new never used McLeod flywheel, clutch disc, pressure plate, & hydraulic throwout bearing I need to sell.
It's for using a Gen 1 Chevy Small Block with an LT1 T56 with a push style clutch (Hydraulic throwout bearing)
Flywheel Part #460300
Pressure Plate Part #360709
Clutch Disc Part #260671
Hydraulic throwout Bearing Part #1362
Interested in any parts? e-mail me: deanchinowith18@yahoo.com
or text 361-571-1026 Dean
I can't post in classifieds yet, can anyone tell me why not?
Old Jun 14, 2012 | 10:54 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
For a 400 you need the externally balanced 2 pc rear main seal flywheel like what Motormouth has or a steel one of that style.
For greeny as said you want everything except the donor crossmember and driveshaft. Generally pedals (or use 3rd gen) hydraulics, flywheel, clutch, bell, throwout fork, torque arm mount, shifter, inner boot, trans mount. Everything. You then will need to get or make a t56 crossmember for a 3rd gen. Also look at clutch prices and throwout bearing prices individually. Alone the throwout bearing is very high.
You will require a dakota digital speedo converter adapter to make the speedo read correct. With this there is no speedo concerns if gears are changed. Reset the speedo adapter and you are good to go.
Read the first several pages of the T56 swap thread at the top, it is very informative and good with pics also.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
