9-bolt cone shim material?
Old Jun 12, 2012 | 12:11 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm rebuilding 9-bolt posi carrier and have figured out the shim thickness I need. I've been looking for appropriate shims and the nearest I've found is Ratech part number 1109. But they only seem to be sold in packs. I only need two. Does it matter what the shim material is? Could I just use a big mild steel washer of the correct thickness? Or cut my own from sheet metal? Or does anyone know where I can buy just two of the correct shims?
Old Jun 12, 2012 | 12:53 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Re: 9-bolt cone shim material?
They are generally hardened steel washers. There is a lot of friction and pressure on those washers. Just buy the shim kit. Too small a washer and you will be peg legging around, too much and you will be hopping around turns with a locked rear.
Could also try tranny shops, they may have a few extra shims they may just give you. Manual trans and Carrier bearing shims come in many sizes and they may have something of the size you need.
There was once a good read on here somewhere showing what thickness shims to use for what style of driving you do. search around. Ill see if I can find it
Old Jun 12, 2012 | 01:17 PM
Transmission: t-56
Found it,
https://www.thirdgen.org/forums/faq-...now-about.html
MrPackstin
Oct 25, 2017 08:09 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
