Hydraulic TO bearing
Old Jun 12, 2012 | 06:53 PM
3rdGenFreak1227's Avatar
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Hi guys Im in the process of swapping 700r4 to T5, I am strongly considering doing a hydraulic TO bearing simply for long tube header room, I know the stock master cylinder will work but I was wondering if anyone had any ideas on what line to use, obviously the master cylinder is a roll pin and so is the stock slave, but the hydraulic TO bearing has a threaded line that takes a flared end, anyone have any idea on how to make a line that will work? I have searched the s**t out of this website and can't find anything on it, Thanks guys
Old Jun 13, 2012 | 02:42 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Hydraulic TO bearing
There was an article in GM High Tech performance magazine about this you should check out. They're using the T5 in their Formula Project Snowball build with a Mcleod hydraulic throwout bearing (MCL-1302 I believe) and show an adapter that is used to connect the two.
Old Jun 13, 2012 | 02:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There are a few different TO bearings, such as the McLeod mentioned in post #2.
You should contact the maker to ask what thread / fitting it uses.
Old Jun 13, 2012 | 02:58 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I'm using a hydraulic throwout bearing. I bought an adapter that uses a roll pin to install it in the master, and then is a -3AN to connect the line too. I think the adapter piece is made by Russel or Earl's. Dont remember though.
88SS6SPEED
Nov 11, 2015 07:05 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
