T5 10 spline What clutch kit?
Old Jun 16, 2012 | 01:50 PM
84TransAmNY's Avatar
Car: 2001 GMC Sonoma 4.3/ 84 Trans Am
Engine: SBC 355
Transmission: 89 World Class Borg T5
Axle/Gears: 3.42 10 bolt
Alright so I was under the impression that I had a v8 T5 but turns out after i ordered my Ram Powergrip I definitely have a v6 t5 with the 10 spline 10 inch diameter clutch. My engine is a 350 that has been completely rebuilt and will prolly have around 300 hp. My question is should I just get a cheap clutch because I will definitely need a a new transmission some day . Or will a better clutch allow the trans to take more abuse? If so what clutch kit should I get?
thanks for any responses much appreciated
Old Jun 16, 2012 | 02:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T5 10 spline What clutch kit?
the v6 has a 14 spline, the ford t5 has 10. what do you have? are the mounting ears of the trans and the trans mount on a serious angle when compared to the case, or are they even.
either way you need a different trans
Old Jun 17, 2012 | 10:43 AM
Engine: SBC 355
I guess it's the 14 spline idk I just know it isn't the 26. The mount is crooked compared to the case. Well it was originally hooked and working normal when I bought the car and took it apart. I guess I am just going to buy a cheap clutch kit until I can afford a good transmission.
Old Jun 17, 2012 | 09:09 PM
Engine: SBC 355
I think I am going to buy a cheap t5 that was made for the v8's and drop it in and run it til it breaks. I just can't justify buying a t56 or tko right now. My funds are tapped after putting madd money into the car.
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
