700R4 automatic transmission shifting problem
Old Jun 21, 2012 | 01:19 AM
Sinner-X's Avatar
Car: 1991 Camaro Z28
Engine: 355 V8
Hey guys! I need your help on an issue I found recently on my 91 Z28. While driving normally, shifting is fine. However, when I slam on the gas while cruising, the car will downshift but gets stuck on the gear, thus reaching redline without shifting to the next gear. It does not do it all the time but it sucks when I go drag racing. I did some research and found out the throttle valve cable could be loose and could be adjusted quite easily. Any insights on that issue? Thanks in advance!
Transmission has been rebuilt 10K ago by the previous owner.
I have a BM Megashifter.
Old Jun 21, 2012 | 01:16 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: 700R4 automatic transmission shifting problem
Sounds like it could be a governor that is sticking. If your TV cable is pulled tight at WOT it is set correctly. The governor and TV cable are really the only two inputs the valve body uses to determine shifts. Hope this helps. Which gear(s) does it do this in?
Old Jun 21, 2012 | 01:20 PM
Sinner-X's Avatar
Engine: 355 V8
The problem seems to be on the third gear only. While cruising fourth gear, it will downshift to third and then redline. Same thing while drag racing, it will go from first to second to third but get stuck on third. Thanks for the precious info, I'll look into it!
Old Jun 21, 2012 | 05:50 PM
Car: '88 Iroc
Oh well that changes things. That is just how 700r4's are. They are suppose to never upshift into 4th under WOT or really anything above half. So if you are cruising at a very high speed in 4th and punch it, it will downshift and stay in 3rd no matter how fast you were going. There is a mod you can do by adding a set screw or two to the TV valve (I think) that basically plugs a hole and allows it to shift into 4th at any throttle. I can't believe you are topping out in third so much. With 3.73's at 3rd gear red line I would think that would put you at around 110-115 mph. Is this correct? Or is it slipping in 3rd and that's what makes it red line?
Old Jun 22, 2012 | 01:07 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Some stock iroc will upshift to fourth at full throttle,but the 3-4 clutches are gone
Old Jun 22, 2012 | 08:11 AM
Sinner-X's Avatar
Engine: 355 V8
Asked my mechanic yesterday who has a third gen trans am, told me the exact same thing I bought the car already modded but I don't know exactly what are the gears, before slamming on the gas I'm usually around 80mph, so I guess it would still be a stock 3.23....
Thanks!
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
BlackphantomZ28
Apr 24, 2016 08:14 AM
drathaar907
Aug 6, 2015 04:20 PM
