rear end romoval
Old Jun 23, 2012 | 08:11 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
rear end romoval
So I searched and found nothing. So is there a thread that goes over it. Really I have two questions. Where to put jack stands. And can rear brums be unhooled in a way so as not to have to bleed them?
Old Jun 24, 2012 | 01:06 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: rear end romoval
Anyone? I know several have done it. BrKes? Locationof stands?
Old Jun 24, 2012 | 08:38 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
This should have been posted in "Transmission and Drivetrain". Stands go under the subframe rails, beside the trailing arms. This is also your jacking point. Don't worry, the rails are flat for enough length to have both a jack and a stand. There's no way to avoid bleeding drums, but it's not difficult, even by yourself.
Old Jun 24, 2012 | 11:43 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I'm swapping my rears out as we speak. I have spohn SFC's, so my jackstands are under those, towards the rear. If you don't have frame connectors, the portion of the unibody that the front of the LCA bolts to has always sufficed for me.
If you don't want to disconnect your brakes from the rest of the brake sysem, what you'll have to do is unbolt the entire hardline/flex lines/drums from your rear and find a way to attach them to the car up and out of the way. You will most likely have to pull your axles out of your rear to be able to separate the axle housing from your drums.
This will probably be more trouble than its worth. You can get 1 person brake bleeding kits from places like harbor freight, or just get a buddy over to help you bleed the brakes when the time comes. Years ago, I removed my A/c system in one piece with the intention of being able to re-install it if I so choose. It ended up being much more trouble than had I just disassembled it, and I don't see myself throwing it in at any time.
If you have any more questions, throw them on up. I'm right in the middle of this, so I can probably answer questions as good as anyone.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
