Rear End Zing/Noise
Old Jun 29, 2012 | 12:07 PM
rffanat1c's Avatar
Car: 1984 Z28
Engine: 5.0L H.O.
Transmission: Automatic
Axle/Gears: IDK
Rear End Zing/Noise
84 Z28 L69 700R4
At any speed and going over a good dip or any time the car extends its rear end travel (up and down), I hear a zing from the rear end. It sounds just like if you pull your lawn mower starting cord while the engine is running and you hear that metallic zing. I can't tell if it is something rubbing on something or if its a wheel bearing. It only happens over bumps and at any speed and sounds as if it is coming from the left rear wheel.
Just for the fun of it, I got out while it was parked and kicked the left rear rim near the center. I could hear the sound of something loose in it...almost as if the rim was just a fraction of an inch away from the hub and it was hitting it when I kicked it. But the wheel is tight. I kicked the other three wheels and they gave a resounding thud with no loose metal sounds. Thanks guys
Old Jun 29, 2012 | 01:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Rear End Zing/Noise
You need to jack the car up, support it on jackstands safely and look for something hanging down that's hitting the driveshaft when the suspension compresses. It's going to be something that's hitting a moving/spinning object and the driveshaft is a more likely than the brakes / wheels.
Old Jun 29, 2012 | 01:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've seen drive shafts groved from parking brake parts. As jmd suggests, take a peek.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
