Drive shaft length
Old Jun 30, 2012 | 06:20 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
Drive shaft length
Is there a place to find how long different drive shafts are with different transmissions ? I bought a roller with a drive shaft loop and an after market trans cross member that holds the torque arm --- I have no engin or trans but have a drive shaft and I'm trying to find out what trans was in the car
Old Jun 30, 2012 | 06:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Drive shaft length
I typed "driveshaft length" in the search box at the top.
About a dozen threads down was this one, which should help answer your question: https://www.thirdgen.org/forums/tran...explained.html
The 700-R4 and T5 drivelines are about 2.92" longer than the 82-83 drivelines for T200-C and 4 speed.
Old Jun 30, 2012 | 08:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If there's any chance that a TH400 was swapped in, then the slip yoke won't be 27-spline. TH200C, 700R-4 and T5 were all 27-spline. IDK about the Super T-10 used in '82 Z28s.
Old Jun 30, 2012 | 08:39 PM
jmd's Avatar
jmd
What about a TH375?
27.
Old Jun 30, 2012 | 08:40 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
It is an automatic , I have yet to climb around underneath . I was under long enuff to look at the floor
Old Jun 30, 2012 | 08:47 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Originally Posted by jmd
What about a TH375?
27.
Forgot about the 375, probably because they're extremely ultra rare and rather pointless, Thanks for the T-10 info.
Old Jun 30, 2012 | 11:29 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
Not sure what this had , think I'm going to pull it out tomorrow and measure it , don't think the yoke is big enuff to be a th400
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
