worth swaping aluminum driveshaft from steel?
Have you guys experienced any difference between, driving with steel and aluminum driveshaft? just asking becuase i´m wondering if it´s worth the money to do the swap?
Re: worth swaping aluminum driveshaft from steel?
I have, at 120mph+ I always had vibrations, now I am running an aluminum shaft and it's silky smooth. Both on my gray iroc and my red one. The red one is still under construction but sofar it's smooth. The gray one I drive daily in the summer and I've had it well over 130mph and no vibration whatsoever
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might find the following dyno info interesting (note the info at the bottom of the page):
http://ws6.com/mod-1.htm
JamesC
JamesC
Car: check
Engine: check
Transmission: check
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Sounds like it is only worthwhile if your stock steel DS has vibration problems. The test actually looks "unfair" to me. I'd must more prefer to see a balanced, non-vibrating steels DS compared to the aluminum one. Otherwise it strikes me like comparing a flat tire to a properly inflated one.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Factory aluminum shafts are not that strong. As long as you're not going to push it really hard, a swap to aluminum will usually be smoother however a well balanced steel shaft is just as good. My custom made steel shaft has no problems handling all the HP I can throw at it and survives 150 mph 1/4 mile passes.
I'd also like to see that dyno comparison using a balanced steel shaft. Chances are there will be no difference in performance.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Had mine redone at Wenco all they do are driveshafts
They all prefer steel over aluminum.
If yours vibrates then fix it. Had both, not worth the cost. Overrated imo.
Car: `86 SS / `87 SS
Would I spend over $300 on a new aluminum shaft to replace a steel one that has zero issues? Probably not. Would I buy a known-good aluminum for less? Sure as long as it wasn't a late 4th gen thin-wall cardboard damped junker.
The main thing on the 82-02 F-body to look at is driveline angles on lowered cars which cause vibration. If an aluminum shaft "solves" a vibration problem that wasn't "caused" by a steel shaft that was in proper working condition, then the problem will eventually show back up and wear the u-joints faster than they would have been.
Another consideration is the driveline speed. A higher numeric rear gear ratio (3.73) is going to have vibration issues at a lower road speed than 3.42 for example.
Car: '87 Flame Red/Carmine Red GTA
Is there anything wrong with the 4th gen. aluminum shafts for stock power and no desire to make more? They came on cars with more power, so what's the problem with them on a car will less power? I want one because I went to replace my u-joints on my stock steel shaft and the ears were bent, so the joints didn't go in too well and it's bent and vibrating.
Car: check
Engine: check
Transmission: check
If it were an '89 TTA and I was turning up the wick, no way, it would get a Denny's steel shaft.
See, I covered both aspects...
RBob.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
I my self spend the money. on a larger stronger alum shaft.
less lbs to spin up..just me
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
350, 4th, 87, aluminum, aluminundriveshaft, camaro, clicking, driveshaft, easier, gen, ontransmission, rear, steel, tpi, transmission, worth
