After market speedo - T56 trans...
Car: 1934 Ford Roadster
Engine: 350 CSB
I have an electric speedometer that I'm not sure how to wire to my T56 trans,
It's an Aurora/AutoLoc speedometer. I know it's low quality China stuff, but that's what I have for now. The Auto Loc mounting instructions only show how to wire against a 3 wire hall effect sensor, but as far as I have understood, the T56 transmission don't have a hall effect sensor, just a 2 wire VSS sensor...?
Here's what their instructions says:
So how du I wire the two VSS wires to the Speedometer?
My suggestion:
-red wire from the speedo to +12V
-black wire from speedo spliced in 2 with 1 wire to ground and 1 to VSS.
-White wire from speedo to VSS.
Does it matter which of the two VSS wires that goes to ground? The VSS pigtail has GM correct yellow and purple wires.
I have tried the AutoLoc customer support, but they didn't understand my question at all. Is it me that's in the fog here?
The car is not a third gen Camaro/Firebird, by the way...
My suggestion:
Car: `86 SS / `87 SS
Re: After market speedo - T56 trans...
Here's what their instructions says: http://img.photobucket.com/albums/v2...ter_wiring.jpg
My suggestion:
My suggestion:
Engine: 350 CSB
Ok, So do you mean I have to mount the hall effect sensor to the T56 transmission? Where does is mount?
rs_z28_vert
Sep 30, 2015 09:47 PM
