12 bolt rear with 4th gen fuel tank?
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Just like it says, does anyone have that combo? That's what I have but I can see clearance problems with the third member. I want to use the 4th gen tank because of ls1 upgrade.
Engine: 4++,350 & 305 CIs
Re: 12 bolt rear with 4th gen fuel tank?
People put 12bolts in a 4th gen with the plastic tank all time.
Car: 88 rs
Engine: ls1
Transmission: t56
I guess I didn't say the 12 bolt has a aluminum truss style cover. The clearance problem is at the top I don't know if a stock cover will help much. The axle will have about one more inch of travel.
Interesting. did you jack the rear up without the springs/shocks in to see if it'll clear???
Car: 88 rs
Engine: ls1
Transmission: t56
Wow I must be breaking new ground. I thought someone else would have a 12 bolt rear and a 4th gen tank combo.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
