What rear end is this?
COTM Editor
I happened to run across are car that is being parted here locally, and the adjustable torque arm caught my eye... then noticed the cover is not a 10 bolt. It this a 12 bolt? Looks like my buddies S60
Might have to try and scoop it up. Used rear end... Anything I should check before putting it in the truck?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: What rear end is this?
that is a borg warner 9-bolt,found stock on some '85-89 thirds-especially
trans ams.
trans ams.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Is it a 12-bolt?
Does it has.....I dunno.....12 bolts in the rear cover, or just 9?
I can't see the full rear end cover in your pic, but I'm betting that it is a 9-bolt since it has the rubber plug for the Inspection/Fluid Fill hole in it.
Does it has.....I dunno.....12 bolts in the rear cover, or just 9?I can't see the full rear end cover in your pic, but I'm betting that it is a 9-bolt since it has the rubber plug for the Inspection/Fluid Fill hole in it.
Engine: 4++,350 & 305 CIs
As said above.
The rubber plug says its a aussie 9bolt.
Used in 350, 305 5sp TPI camaro IROCs/Zs, T/As, Formulas,GTAs and 3.8 TTAs from 85ish to 89.
The 89s have the best rear brakes, PBRs, The iron caliper rears are not so good, just because of the brake setup. The rest is the same.
COTM Editor
Thanks guys! Yeah I wouldn't have even asked if I could count all the bolts... thanks
CL pics suck.
Yeah Just didn't want to waste my time driving a couple hours if it wasn't worth it, and it appears now that it is not worth running down and picking up. Thanks again for the quick reply.
CL pics suck.Yeah Just didn't want to waste my time driving a couple hours if it wasn't worth it, and it appears now that it is not worth running down and picking up. Thanks again for the quick reply.
Car: GTA
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
