93 4l60 tcc lockup
Old Aug 5, 2012 | 10:00 AM
bubbachuck7's Avatar
93 4l60 tcc lockup
anyone know how or where i can get a lockup kit or do it myself it has a 5 pin plug and i have only found one kit thats 200 bucks any help would be appreciated
Old Aug 8, 2012 | 08:46 AM
Re: 93 4l60 tcc lockup
anyone? any help here?
Old Aug 8, 2012 | 01:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can get a replacement 5 pin plug and wire it yourself, or you can change the case connector in the transmission for the 4 pin version.
Old Aug 8, 2012 | 01:36 PM
i could get a plug off ebay im sure, but how would i go about wiring it up? thanks for the reply
Old Aug 8, 2012 | 01:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pins A through D have the same functions as they do on the 4 pin version. Ignore the fifth pin E.
Old Aug 8, 2012 | 02:01 PM
and what are their location? the 4 pin only has 3 wires so how does it work the same as you say a-d which is 4? sorry this whole lock up plug thing is blowing my mind lol but thanks for your help thus far
Old Aug 8, 2012 | 02:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The letters are molded into the connectors.
Old Aug 8, 2012 | 03:17 PM
so what are the usages on the 4l60 connectors as you say use just 4 same as a 700r4 but they only have three wires so what do i wire and where to?
Old Aug 8, 2012 | 03:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
https://www.thirdgen.org/forums/carb...c-control.html
Old Aug 9, 2012 | 03:41 PM
None of them say anything about the 5 pin plug and their functions which is what I'm after
Old Aug 9, 2012 | 04:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The functions of each pin are the same in the 4 and 5 pin versions.
Old Aug 9, 2012 | 05:16 PM
So I only need to use the three wires on the five pin and disregard the other two correct?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
seiplentz
Aug 19, 2019 06:02 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
