700r4 to 350 swap (shifter cable)
Car: 1986 trans am
Engine: 355 sbc
Transmission: th 350
i got the swap done torque arm mount installed cant figure out what to do with the shift cable can i use the factory shifter or do i need to go aftermarket
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 700r4 to 350 swap (shifter cable)
Im not saying you have to go aftermarket, but If I did a th350 swap id probably go ahead and swap to a b&m mega shifter setup, i believe the "stock fitting" style has the ability to be used for 3 or 4 speed transmissions...
Car: 1986 trans am
Engine: 355 sbc
i understand park,reverse and neutal will be the same but is 2nd goin be low if i use the factory shifter
Car: 1991 Z28 1LE
Transmission: 4l60e
i would assume, so, OD would be drive, D would be 2nd and 2nd would be low
Car: 1986 trans am
Engine: 355 sbc
alright thanks for your input this swap is turning into somthing haha anyway i guess im going for a ratchet shifter thanks
