speedo problem
Old Aug 12, 2012 | 09:23 PM
kyle39's Avatar
Car: 1986 trans am
Engine: 355 sbc
Transmission: th 350
speedo problem
any ideas for the swap my 86 ta has an elctronic speedo, th 350 is mechanical any ideas
Old Aug 13, 2012 | 12:07 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: speedo problem
I believe summit racing sells a conversion kit or either that i think u could take the one from the 700r4 an just swap it over
Old Aug 13, 2012 | 02:11 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: speedo problem
If you have a small speedo hole in the tailhousing, you need the speedo gear stuff and VSS for a 5 speed 86 T/A.
Or, the 700-R4 tailhousing bolts onto the 6" tail TH350, or it can bolt onto a 9" tail TH350 if a switch-kit spacer is used.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
