5 Speed Transmission for 350 Small Block
Old Aug 21, 2012 | 12:15 PM
jimmy21480's Avatar
Car: '92 Camaro RS
Engine: 350 Small Block from an '83 Cutlass
Transmission: 5 speed T5
Axle/Gears: 1:3.73
Hi All, I have a '92 RS that was originally a V6. I have an Olds 350 in there now, but the stock tranny is still in there. Must be a T5 i presume. The bearings in the tranny are very tired and almost thrown out. My question is, what is a good, cheap 5 speed transmission that can handle around 400 HP??
Old Aug 21, 2012 | 01:11 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: 5 Speed Transmission for 350 Small Block
Its not the hp ratings that matter its the torque ur prob better off puttig a auto in it 700r4 or the 200r4 out of a monte carlo ss car if u want to keep the standard setup get urself either a tko500 or either a t56 swap kit from a 4th gen 93-97 trans am or camaro totally worth doing an ull get two overdrives out of it
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
