Factory Speedometer gear question
Old Aug 22, 2012 | 10:54 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Anyone know which tooth count and color the driven and drive gears were on a factory 3.23 car? I know a lot of you have done gear swaps and have moved up in ratio, and if possible I'm hoping someone still has these gears.
Old Aug 22, 2012 | 11:06 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Factory Speedometer gear question
It takes a 15 drive gear and I think a 37 driven gear.
Check here:
www.bowtieoverdrives.com
Old Aug 22, 2012 | 11:29 AM
actarnoff's Avatar
Engine: 355 TPI
You are a life saver, Don.
Old Aug 22, 2012 | 01:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The gears would be different, of course, for a T-5.
JamesC
Old Aug 22, 2012 | 01:11 PM
actarnoff's Avatar
Engine: 355 TPI
It's a 700r4.
Old Aug 25, 2012 | 08:12 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Depends on tire size. For 245/50R16 use 15:38, for 215/65R15, or the rare 235/60R15 option, use 18:45
Old Aug 28, 2012 | 12:23 AM
actarnoff's Avatar
Engine: 355 TPI
It seems the closest I can find to that is 15:37, I can't find a 38 driven gear for a VSS anywhere.
Old Aug 28, 2012 | 03:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
GM part # 25513045
this place had one in July
http://www.ebay.com/itm/ACDELCO-OE-S...-/170781049857
http://gmoem.com/oem-parts/25513045.html
http://www.gmpartsdirect.com/results...umber=25513045
http://www.gmpartseast.com/parts/gm-25513045_gear.html
Old Aug 28, 2012 | 07:08 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you'd check my sticky about 700R-4 speedo gears, you'd see the GM part number is 25513045. GMPartsDirect.com has it for under $5.
Old Aug 28, 2012 | 12:02 PM
actarnoff's Avatar
Engine: 355 TPI
I've gone down that route, it seems that shipping and handling is $400. I'll call them but it seems unlikely they will have that in stock.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
