Junkyard Manual Transmission
Old Aug 27, 2012 | 01:29 PM
jimmy21480's Avatar
Car: '92 Camaro RS
Engine: 350 Small Block from an '83 Cutlass
Transmission: 5 speed T5
Axle/Gears: 1:3.73
Hello All, Does anybody know what type of car/truck i can get a good manual transmission out of at the junkyard? I currently have a 5 speed T5 that isn't doing well paired with my small block 350. I'm looking to spend less than $1,000. Any help would be greatly appreciated.
Old Aug 27, 2012 | 01:49 PM
highgear's Avatar
Car: 1988 IROC-Z
Re: Junkyard Manual Transmission
All I know of is either a T5 from an 80's camaro/firebird, all tho I have been told you can strengthen a T5 for about a grand... I'd look in to rebuilding/enhancing the T5 or save for a T56 swap.
Old Aug 27, 2012 | 01:52 PM
jimmy21480's Avatar
Car: '92 Camaro RS
Axle/Gears: 1:3.73
are there performance parts available to rebuild the T5? case? gears?
Old Aug 27, 2012 | 02:09 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Dont waste your time spending what a T56 would cost to beef up a T5 to be still weaker than a T56.
Get another F-body T5 and call it a day. They're 200-300 a piece, really not too bad. If you break that one maybe you need to get a T56, but a "350 from a cutlass" shouldn't be too hard on it. And you will definitely need a 83-92 F-body specific T5.
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
the t5 needs to be from a f body in factory form. They have a 15 degree offset that's unique to 3rd gens. They do make upgraded internals but the weakness is the case itself. I have seen out there stronger cases, but I believe they are crazy expensive. IMO, you would be better off switching to a six speed for probably the same amount of money it would cost to upgrade the t5 properly.
Old Aug 27, 2012 | 02:14 PM
highgear's Avatar
Car: 1988 IROC-Z
Yeah I know Gforce transmissions.com rebuilds them, I think they have parts available on jegs or summit. Or you can send it to gforce. I've heard it runs about 900 or so.
Old Aug 27, 2012 | 02:16 PM
jimmy21480's Avatar
Car: '92 Camaro RS
Axle/Gears: 1:3.73
thanks. i'll check that out
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
