Can anyone tell me what I have?
Old Aug 24, 2012 | 08:03 PM
mustangdmurder's Avatar
Car: 1982 Z28
Engine: three 350s, all casting #370010
I was wondering what kind of transmission my Camaro has. It is a 1982 Z28 that had an LG4 from the factory, but I don't think that matters cause I know the tranny was replaced. Here are some picture, so can anyone tell me what it is?
Old Aug 24, 2012 | 08:56 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: Can anyone tell me what I have?
Get a picture of the tranny pan. There are sites that show all the trans id by there pan shape and bolts. I have a printed copy if you cant find them
Old Aug 24, 2012 | 10:52 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Yeah, it'd be easier to tell by looking at the trans itself rather than these casting numbers. If the pan is rectangular it's a 700R4. If it's rectangular with a notched corner on one end, then I think it's a 2004R.
Old Aug 24, 2012 | 11:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Going by the three shift levers on a side cover shown the pic it is a manual trans
Old Aug 24, 2012 | 11:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Given the location of the reverse shift lever on the side cover ( not in the tailshaft housing as some other GM trans have ) it would appear to be a Saginaw trans
Should be 7 bolts holding the side cover onto the trans case
Old Aug 25, 2012 | 09:28 AM
Sorry for your bad luck
Old Aug 25, 2012 | 10:27 AM
Car: 1982 Z28
7 bolts holding the side cover on the transmission case. It is a Saginaw. What power output are they rated to?
Old Aug 25, 2012 | 01:31 PM
Doesn't matter. They're terrible, for any number of reasons other than and in addition to any meaningless "rating". Bad gear ratios, clunky shifting, and so forth; and of course, just overall weak.
Old Aug 25, 2012 | 03:45 PM
Car: 1982 Z28
So in other words it needs to come out and a M21 needs to go in?
Old Aug 26, 2012 | 05:07 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
A Saginaw iron-case with the 2.54:1 first isn't a total disaster, and is adequate to a 400-horse 350 on street radials. I drove such a combo in a '75 Camaro I used to have. 265/50R15s and a 3.42:1 rear. The M21 sucks because the 2.20:1 first means you need a 4.10:1 axle to get a combined 9:1, about the minimum for any street 350 with typical 26" tires. The Saginaw isn't much better, needing a 3.55:1 rear. And both suck because neither has any OD. If you're going to street-drive a 4-speed with a 350, get the wide-ratio Super T-10 your car should have, with the 3.42:1 first, and combine that with a 2.73:1 axle. That'll survive 300 HP. If you want more, invest in a used T56 from a '94-'97 Z28.
Old Aug 26, 2012 | 08:52 AM
No...
A T-56.
Last year for the M21 was about 74. None of them have torque arm provisions.
A T-10 from a 82 F body would be the only "direct" "upgrade"; but then, you'd still only have a 4-speed. No OD.
The T-56 has basically the same gears 1 - 4 as a Muncie or T-10, but then adds 2 more ODs on top of that. Pair that up with a real high # rear gear (3.73 MINIMUM) and you end up with a car that launches like a 60s muscle car but cruises at the low RPMs and high vehicle speeds of a modern one.
Old Aug 26, 2012 | 01:32 PM
Car: 1982 Z28
A T-56 would be awesome, but I don't have $1500 or more to spend on a tranny and I won't for a while because I am starting tech school tomorrow. What would be the best Tranny I could get and rebuild myself for about $300-400?
Old Aug 27, 2012 | 06:08 AM
There isn't one.
Old Aug 27, 2012 | 04:03 PM
Car: 1982 Z28
So there are no alternatives?
Old Aug 27, 2012 | 04:15 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
nope. either dont beat on the car and keep the saginaw alive or be prepared to drop some cash. cars arent cheap and theres always kooks to swapping in anything that didnt come in the car from the factory
Old Aug 27, 2012 | 05:42 PM
Car: 1982 Z28
My poor Camaro is never gonna get done.
