truck 700r4
Old Aug 31, 2012 | 11:52 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
truck 700r4
can a truck 700r4 fit in our cars? and if so what all has to swap and what type of truck should i look for? i have a 700 behind my v6 so i have most the stuff i can rob off of it for my swap but need to know if this would work, it seems like truck 700r4s are plentiful around here, 2 wheel drive and 4 wheel drive.
Old Sep 1, 2012 | 12:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: truck 700r4
A T700 is a T700 ; the tailshaft housing varies depending what it was originally installed in so you would have to fit your 3rd Gen housing to any T700 you buy
4WD should have different ( shorter ) output shaft to mate to the transfer case so stay away from those
Old Sep 1, 2012 | 06:31 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: truck 700r4
Assuming you're planning to do a V8 swap: Get one from '88-'93, codes are stamped on the passenger side, towards the rear, just above the pan. Get one from a V8, the 4.3 versions don't have as many frictions and steels inside. Plan on a 'vette servo. Plan on swapping your shifter bracket. The V6 case you have uses a different bellhousing pattern from the V8 versions. Torque converter pilot is also smaller than V8-spec. V8 guts can go in V6 case.
Old Sep 1, 2012 | 09:58 PM
Engine: L31 350
Re: truck 700r4
im going to get an 87 up, so that it has the anti-abuse valve in there lol. im swapping the trans in with my 350 so im hunting down a v8 trans. can i use my v6s bellhousing bolts and torque converter bolts?
Old Sep 2, 2012 | 06:48 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: truck 700r4
Nope, sorry.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
