T5 clutch fork alignment
Old Sep 1, 2012 | 07:48 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
okay, so i had my clutch fork perfectly aligned with the throw out bearing when i bolted my T5 months ago. now, after replacing the clutch slave cylinder the clutch fork is no longer pushed into the throw out bearing all the way, and wobbles around with lots of play on it.... so is there any trick to getting the fork back on without removing the transmission?
any ideas at all would be helpful, i'm just trying to avoid more work than necessary.
also the car was never driven from the time the tranny was first installed to when the clutch fork popped out.
Old Sep 1, 2012 | 08:23 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: T5 clutch fork alignment
Some play is fine as long as you have the tabs on the clutch fork inside the outer race on the throwout bearing. Like this - https://www.thirdgen.org/forums/atta...g-assembly.jpg
Old Sep 2, 2012 | 08:04 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ck. that pivot ball/stud has not backed out . happened to me , good luck .
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
