rear axle swap
Old Sep 21, 2012 | 09:00 PM
elcamman50's Avatar
Car: 1987 formula
Transmission: 700r
rear axle swap
Hi. I was just wondering if I could swap my rear axle out of my 88 GTA to my 93 Trans Am? I know the rear disc brakes are different, but can I bolt on my rear backing plates and disc brake system to the GTA axle. I just think the the rear in this car is to weak and would rather upgrade it to my old GTA rear I have in my garage. Let me know what you guys/gals think....Thanks, Charlie
Old Sep 21, 2012 | 09:14 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rear axle swap
Direct bolt-in yes, but chances are that your GTA has a 9-bolt rear end. If it is the original rear end? Then it does.
While the 10-bolt brakes can be adapted to a 9-bolt rear, they are not a 100% direct bolt-on & will require some mods to be done.
Old Sep 21, 2012 | 09:25 PM
Car: GTA
Re: rear axle swap
And the 4th gen rear is 4" wider, 2" per side, so you would have to use the 3rd gen wheels, unless you get aftermarket wheels in a 3rd gen fitment.
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
