700R4 HELP WITH SPEEDO !!!!
Old Sep 24, 2012 | 08:56 AM
Boonze's Avatar
Bought a 87 Firebird, previous owner did a 2.8 v6 to carbed v8 & 700r4 swap, the tranny has the 2 wire speed sensor, 1 yellow and 1 purple wire, which are butt connected to the harness wires of the same color, traced the wires up to passenger compartement, they go into a yellow buffer box, then a green goes to the guage. When i'm moving the speedo is pegged at max, when stopped it goes to 0, any help would be MOST appreciated.
-BBBoonze
Boonzey@gmail.com
Old Sep 24, 2012 | 12:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700R4 HELP WITH SPEEDO !!!!
Sounds like it has a truck 40-tooth trigger wheel instead of the proper 4-pole VSS. In this case look for a DRAC from a truck and wire that in place of the 4-out buffer box.
This is actually a better way to go then getting the correct VSS. As a DRAC box is strap-able for different rear ratios and tire diameters.
RBob.
loud91rs
Oct 5, 2015 10:05 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
