10 bolt Rebuild.. what locker to get??
Old Sep 30, 2012 | 09:12 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
i rebuilt and built up the trans then put in a 383 vortec now its time to build up the rear end to handle that 383 i have the stock 10 bolt with 273 gears i thought they where 342s but what ever i wanna go with 373s and a locker scince its limit slip right now i want a full posi but after searching for what to get i have no clue on what locker is right for my set up and what i need besides that
Old Oct 1, 2012 | 12:54 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: 10 bolt Rebuild.. what locker to get??
What are you using the car for ? A full posi. as you call it is actually called a spool and used for track .(1/4 mile straight line racing).Limited slip/posi. is used for road racing and street/strip .If its track with hard launches than 9" OR 12 Bolt may be in order.
Old Oct 1, 2012 | 07:01 AM
big gear head's Avatar
You are probably going to break the 10 bolt, but if you want to build it then use a 28 spline Eaton Posi and a set of 28 spline axles. Your 26 spline axles are too small.
Limited slip and posi are the same thing. What you have right now is a standard differential.
Old Oct 1, 2012 | 12:43 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
its a street/strip car i just dont want something like i have now that will kick out to one wheel
Old Oct 1, 2012 | 12:47 PM
Get a Detroit Locker. They never let one wheel spin alone, but still work fine on the street.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
