Recommendations for t 5 or should I say clutch
Old Oct 6, 2012 | 01:09 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Ok so I searched and read and still am clueless. And no I am not swapping a in a 6 speed. Can anyone give a newbie sound advice and a parts list of what will be needed to replace the clutch in my iroc. Which clutch is best for for the money. It not gonna be a drag car or anything it's a convertible. I want to cruise and enjoy a spirited drive or the occasional burn out to show off. Clutch is slipping terrible now but the car only has 69,000 miles so. Any advice?
Old Oct 6, 2012 | 02:18 PM
Re: Recommendations for t 5 or should I say clutch
Just get a stock replacement one at a parts store.
Installation perfection is FAR more important than the choice of parts, in this situation. Concentrate on that instead.
You need a clutch kit and a pilot bearing and some trans fluid. Maybe a handful of "might as well"s that you'll be in the middle of at the same time, like trans mount, toruqe arm mount, U-joints, etc. You'll have to be the judge of that.
Old Oct 6, 2012 | 02:41 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Like Sofa said, a stock replacement should work fine....but I'd add checking out your flywheel and look for burnt/hot spots since it's been slipping.
If it's bad enough, you may need to remove it, take it to a machine shop so they can turn it down/clean it up.
Old Oct 6, 2012 | 08:25 PM
Benc1's Avatar
Thanks for the info but now I got another question. went to parts store this evening and they want to know if I have a 10 spline or 26 spline How will I know this until I get under the car taking it apart
Old Oct 6, 2012 | 08:41 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
You can search this site. It has all the answers to almost any question you could imagine. From the factory V8 cars equipped with the T5 came with a 26 spline input shaft.
Old Oct 6, 2012 | 10:40 PM
Benc1's Avatar
I agree about searching the site but most of the time I search and read for hours. I then have to decide what's fact and opinion. And then more times than not I'm left with more questions than when I started
Old Oct 7, 2012 | 07:37 AM
Yeah I feel your pain... I wish there was some way we could zap all the drivel and repetition of "mythology" and all that sort of stuff, and trim it down to nothing but the facts; but that seems beyond reach somehow...
Old Oct 7, 2012 | 08:16 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's all opinion. It only becomes fact when you verify it for yourself.
-- Joe
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
