Vss wiring?
Old Oct 10, 2012 | 11:36 AM
direngrey's Avatar
Vss wiring?
Hello all,
I have done a v6 to v8 swap in my 87 firebird and am just troubleshooting the speedo my engine and trans came from a 84 firebird se and I have swapped the cable drive to the electric vss and the gears and ran the pins to the c100 to keep the wiring Unhacked. I kept the interior harness from the 87 and am using the engine side from the 84 so I just put the pins for the vss into the engine side the should be in the correct spot to mate with the interior side of c100.
Still no speedo?
Either my vss is broken or I put the pins in the wrong spot on the engine c100?
Or am I missing something? I shouldn't have to mess with the buffer box since I used interior side from 87?
Old Oct 17, 2012 | 07:37 AM
RaceFace's Avatar
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
Re: Vss wiring?
was '87 V6 supplied with yellow buffer box or wires from vss go straightly to ecm and then to speedo?
Old Oct 17, 2012 | 08:47 AM
direngrey's Avatar
Re: Vss wiring?
The wires go from vss (purple and yellow)?to c100 (engine side from v8 '84) then from c100 (interior side '87) to buffer box it's in the dash right beside ECM. All my other electrical is working except speedo.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
