Richmond Street 5-Speed Problems
Old Oct 12, 2012 | 11:51 PM
Josh029's Avatar
Car: 1984 Trans Am
Engine: 1996 Corvette Lt1
Transmission: Richmond 5 speed
Axle/Gears: GM 3.27
I have a street 5 speed and I am having problems shifting with this transmission. I have torn it apart and inspected the syncros and they seemed fine. I have heard that that are notoriously difficult to shift, but I was wondering if anyone has found a way fix to this? Input would be greatly appreciated.
Old Oct 13, 2012 | 06:26 AM
Gary Anderson's Avatar
Re: Richmond Street 5-Speed Problems
Brian at SK Speed is a master with these things.
http://www.skspeed.com/manual-transmission-shop.aspx
Old Oct 13, 2012 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, and very difficult to shift when cold. It may sound strange but it will shift better when the RPM is run up higher.
For fluid use straight 30W non-detergent regular oil and add a bottle of posi additive to it.
RBob.
Old Oct 13, 2012 | 10:03 AM
Josh029's Avatar
Car: 1984 Trans Am
Axle/Gears: GM 3.27
Thanks for the replies! I will definitely try the 30w and the posi additive before I go the more expensive route and have it sent in to be looked at.
jhawkeye
May 25, 2022 06:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
RedLeader289
Jan 22, 2016 03:05 PM
Reborn756
Sep 4, 2015 03:42 AM
