Parts Necessary 4 T-5 swap
Old Oct 14, 2012 | 07:28 PM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
I have the tranny, shifter, bellhousing and clutch.
I know I need the pedals. What else is needed? Tranny's are a black hole for me. So this should be fun lol!
Thanks!
Adrian
Old Oct 19, 2012 | 06:32 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: Parts Necessary 4 T-5 swap
I'm doing that swap right now. you will need (hopefully i don't miss anything):
flywheel
pilot bearing
clutch disk
pressure plate
throw-out bearing
throw-out bearing fork
bell housing
transmission
clutch slave cylinder
clutch master cylinder
clutch reservoir
brake/clutch pedal assembly
lower shift boot
upper shift boot
manual shift plate for center console
I think that is everything.
also, read the T-56 swap sticky thread in the Transmission board. It has tons of useful information. that is the thread that I read about 5 times before starting my swap. This is the first time I have messed with transmissions myself and the swap isn't that bad to do. Seems overwhelming when you think about it and start, but it comes together fast and isn't actually that bad of a project.
-Adrian
Old Oct 25, 2012 | 01:45 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
You will need to have a torque arm mount and as said above look at the t56 swap thread. It will give you a good idea of what to do and how to do it. Pay attention to the wiring for the neutral start and reverse lights.
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
