Should I replace this flywheel?
Old Nov 1, 2012 | 04:21 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Clutch went out and the springs got up in there and roughed it a bit...the surface doesn't seem too bad could be machined out...
Heres a picture
And here is the clutch
What do you guys think?
Old Nov 1, 2012 | 08:15 PM
Re: Should I replace this flywheel?
Do you enjoy having feet?
Next time you're up under your car, observe how close that flywheel, spinning at ???? RPM (crankshaft speed), is, to your right foot. It's actually no more than 4", maybe as little as 3".
I like walking sometimes.... if my own looked like that, it'd go in the trash.
Old Nov 1, 2012 | 10:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I think you need to install a scatter shield when you re-assemble.
Old Nov 4, 2012 | 02:24 AM
mbolte's Avatar
Car: 1987 Camaro
This is a really good point that didn't cross my mind. Thanks I'll be getting a new one.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
KO1
Aug 31, 2015 06:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
BBSDesigns
Aug 11, 2015 07:39 PM
