valve body replacement
Old Dec 4, 2012 | 08:38 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
so ,not being well versed in auto trans repair.how hard is it to replace the valve body in a 700-r4? what to look out for? any thing overly difficult? see my trans dont shift out of 1st gear .and ive been told that its valve body has something stuck.any body with knowlege on this subject?any hints or tips?
Old Dec 5, 2012 | 11:28 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: valve body replacement
I would check the govenor gear first.
Old Dec 12, 2012 | 08:18 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
the only thing that would be in the valve body causing it not to shift into 2nd would be the Tv cable plunger. Other than that it sounds like your 2-4 band is a goner. You will probably have to pull the trans and get it rebuilt or the 2-4 band replaced along with a new 2-4 servo
gta90
Sep 15, 2015 04:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
