Some shops cant be trusted
Old Dec 10, 2012 | 05:00 PM
Loswa's Avatar
Car: 1986 IROC-Z
So since I been busy lately I had one of the local shops do an oil change. Suddenly after leaving the shop my car is now leaking from the trans pan and the power steering seals. I had no leaks whatsoever before I got there.
I went back and of course they claim they informed me about it when they did it and my roommate was there as my witness.
Anyways, so what's your take on it? Easy fix on the trans pan? could it be just tightening bolts or new one? Its a 700R4.
Also power steering seals, how much of a hassle or even costs?
Greatly appreciated for any input.
Old Dec 10, 2012 | 05:05 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Re: Some shops cant be trusted
So you think they did what? loosened your pan bolts to create a leak and somehow damaged your power steering seals? come on now..
Old Dec 10, 2012 | 05:25 PM
Loswa's Avatar
Car: 1986 IROC-Z
I had not noticed the shop did have bad reviews. The seals i know seems unlikely. Trans pan tho its easy. I had absolutely no leaks on the car. By the time I got home let it sit a few hours, im having oil spots on the driveway which was clean beforehand. Landlord gets bitchy about oil so i check every time i move my car.
Old Dec 10, 2012 | 05:27 PM
Loswa's Avatar
Car: 1986 IROC-Z
Just checked power steering, the cap was lose, refilled and tightened. Turned on the car for a few minutes, let it sit, got under the engine but no leaks so far.
Going to try tightening bolts on trans later.
Old Dec 10, 2012 | 05:41 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
A lot of times shops do a poor job of cleaning up behind themselves during the oil change. When you take the filter off, it's inevitable that oil is going to run down on the block and other places, if they dont clean it up well, you will notice some "leaks" that weren't there before. That could be another possibility so check that as well
Old Dec 10, 2012 | 06:16 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
they might have done it on purpose to charge you more. maybe one of the guys thought the power steering cap was the oil cap. or they thought you wanted your transmission oil changed and realized halfway.
Old Dec 11, 2012 | 10:28 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Here's my theory. They popped the cap on the power steering fluid to see if it needed fluid, then didn't tighten it back up. I actually had that happen with my master cylinder at goodyear.
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
