Harsh 1-2 shift
Old Dec 10, 2012 | 09:12 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Harsh 1-2 shift
I just got done installed a freshly rebuilt transmission I. Behind my fresh rebuilt vortec 350, I noticed tonight that the 1-2 shift is really mean, it will jar you under light throttle even, the motor doesn't scream when it goes to shift, the rpms raise alittle higher than I'm use to before it shifts but not horribly, and th e rest of the shifts are firm. As it warms up alittle it gets alittle softer but still worried me, I installed a new tv cable for an 86 4bbl camaro, have the correct throttle bracket bolted to my carb throttle plate, and the correct bracket that holds my cables in place, when I adjusted the cable I heard three clocks as your suppose too, but the last click was alite hard to get, it was near the end of the throttle and the cable tightened up alot before it clicked in they off time. I'm not sure what all was done to the transmission besides a Rebuild so it could have a shift kit or something inside it. Help?
Old Dec 11, 2012 | 12:08 AM
morgsie's Avatar
Re: Harsh 1-2 shift
I have never heard of the tv cable making "3 clicks". It should ratchet as you roll the throttle forward and that's it. Once it's set it shouldn't ratchet anymore. Older cables can be harder to set. If you are worried get a 300 psi pressure gauge and check transmission pressures.
Old Dec 11, 2012 | 07:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Harsh 1-2 shift
They may have blocked the 2nd accumulator and/or drilled the 2nd feed hole in the plate a bit more then they should have.
RBob.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
