differentail help.
Old Dec 31, 2012 | 11:46 PM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
differentail help.
10 bolt 7.5 i am puting 4.10 gear in what shims should i start with?
Old Jan 1, 2013 | 12:06 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: differentail help.
The ones that are currently in the diff and behind the pinion gear.
Unless you have a test pinion bearing modified to slide on and off without a press, you'll never "guess" at what shims to start with. Once you press the bearing on, you're not going to get it off to change the shims without destroying it.
Old Jan 1, 2013 | 03:41 AM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
can i use the carrier shims for pinion shims?
Old Jan 1, 2013 | 09:15 AM
big gear head's Avatar
No. When you ordered the gears you should have also ordered a good installation kit. It would have made the job much easier. If you have a press with a bearing seperator you can press the pinion bearing off and on without damaging it. There is a good thread on this sight that covers gear set up with a lot of pictures. Check the 10 bolt sticky and see if there is a link there.
Old Jan 1, 2013 | 10:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I hope your not going to run a sticky tire with the 4.10s.
They tend to break the pinion teeth off easy..
Old Jan 1, 2013 | 04:00 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
ive broke 9 410 gears but this is the frist one ive set up my self lol
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
