mercon v in th350?
Old Jan 15, 2013 | 08:29 PM
t-hale7's Avatar
mercon v in th350?
hey guys, i just put in a new converter(higher stall about 2800) and a shift kit in my th350 (came form a 76 Malibu) i installed it in my 82 bird and am about to fill it up with fluid. i have a full case of mercon v fluid sitting under the work bench(i work at ford and have managed to collect a pile of it) now i have done a bunch of reading and i keep finding ppl saying to use dex3/mercon..... since mercon v is backwards compatible with mercon could i use it in my th350? has anyone tried this before? any help/suggestions is appreciated.
Old Jan 15, 2013 | 09:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: mercon v in th350?
Pretty well all ATF is backwards compatible. The newest stuff available should have no problems working in older transmissions. If the transmission is old enough, the dipstick probably says to use Dexron II. That's not even made any more.
Old Jan 16, 2013 | 08:11 AM
t-hale7's Avatar
okay, i guess ill have to try it and see. thanks
Old Jan 16, 2013 | 08:28 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have heard of shops switching trucks from mercon TO dexron . dexron they say has a higher boiling point . i'm not sure about the boiling point stuff . i would go ahead use what you have . good luck .
Old Jan 18, 2013 | 08:30 AM
t-hale7's Avatar
thanks for the input guys, i do have another simple question though. i bought a lokar dipstick but its way to short, it barely reaches the back of the rh cylinder head, im wondering will any th350 factory type dipstick work? or should i buy a longer braided/flexible type? thanks
Old Jan 18, 2013 | 06:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
As long as it's for a Chev engine. A TH350 on a Pontiac, Buick etc may have the retaining tab in a different position because of the different bellhousing bolt patterns.
There's 2 different seals for the tube depending on the size of the tube. If you grab a junkyard tube, make sure you get the seal at the bottom just to be safe.
The Lokar braided tubes look nice on a street rod or dragster where it's visible. On a typical production car, it's a waste of money.
Old Jan 18, 2013 | 07:07 PM
t-hale7's Avatar
cool thanks, i just didnt know if the spae of the tube would work in this chassis, that why i considered a braided one. but ill just try to find an oem one. thanks
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
