Clutch engaged and loud whining and smoking?
Old Jan 23, 2013 | 10:42 PM
morries's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I just replaced the slave cylinder on my 92 camaro, bled the line, started the car with no problems but when I pressed the clutch in a loud whining started I tried to release the clutch pedal and nothing changed. I then pressed in the clutch again and released still nothing so I shut the car down, got under the car and noticed the slave cylinder was fully extended. I loosened the bleeder bolt and it retracted. I then went through the bleeding steps again and made sure the cylinder was extending and retracting. Now when I start the car I hear this kind of rattling noise especially when i press the clutch in. What could this be?
Old Jan 24, 2013 | 05:32 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Clutch engaged and loud whining and smoking?
sounds like the fork slipped off at some point and you installed it behind the throughout bearing instead of in the grove . only a guess......
FormulasOnly
Jul 23, 2018 08:47 AM
loud91rs
Oct 5, 2015 10:05 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
