T-5 leaks out. bolts.to bell-housing
Car: `86 SS / `87 SS
Re: T-5 leaks out. bolts.to bell-housing
Out the front is either a bad seal, or stretched case. The case problem will show up around the countershaft front bearing race.
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
It stretches, from being overloaded.
Since you have a 1st design transmission, it will look like the top trans in this pic. (Lower is the 2nd design, 88-up or whatever year it was) Notice the stain below the front countergear bearing, which is the round thing about 2" in diameter below and to the left of the clutch gear bearing retainer. That's how this one died. That's how yours died. That's pretty much how they ALL die. That's why it's POINTLESS to "rebuild" it; the case is destroyed. NO AMOUNT of "rebuilding" no matter with what "kit" will EVER fix that. It is used up permanently completely totally altogether and forever. End of life. In pace requiescat.
Engine: 4++,350 & 305 CIs
