4 th gen axle aftermarket wheels.
Car: 92 RS
Axle/Gears: 3.08
If this is in the wrong forum sorry. Also yes I searched for awhile and tried different terms.
I have read the post about factory wheels and the 4 th gen rear. I however haven't found a post about aftermarket wheels. My car (92 RS) came originally with the 16 in wheels. I know they will not rotate from front to rear. The wheels I'm currently running however do. My question is will they stick out in the rear like factory wheels with a fourth gen rear? Car is in signature if you guys are wondering what the wheels look like.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 4 th gen axle aftermarket wheels.
They are going to move out about 1.5-1.75 inches.
I'm guessing so. It's hard to tell from you photo but it doesn't look like your rear wheels are abnormally tucked in.
Car: 92 RS
Axle/Gears: 3.08
They are pretty much even with the fronts. I'll do some measuring then and compare it to the 4th gen stock wheel thread. Thought if they would not stick out as much I'd go with a 4th gen rear cause it's a little harder to find a 3rd gen one. Thanks for your input.
1992rs/ss
16
Jan 28, 2016 09:58 PM
