9 bolt needs TLC?
Old Feb 24, 2013 | 12:21 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
9 bolt needs TLC?
Hey guys, busted my 9 bolt open the other day and pulled the carrier out, thinking it could probably use a shimming before I throw it into the car. What do you think? I'm really hung up as to whether or not it needs attention after reading this article and looking at the clearance window...
http://www.9bolt.com/technical.html
Pictures of mine:
^^ some surface rust flakes fell in for this picture, that's all that is.
Old Feb 24, 2013 | 12:46 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 9 bolt needs TLC?
Looks like the cones haven't bottomed out yet. However, as you have the carrier out you may as well take it apart and reshim to get it back as close to 'new' as you can. Then you can also make sure the cones haven't started to contact the raised center in either of the carrier halves.
Old Feb 24, 2013 | 12:58 AM
Engine: LB9
Well that's a relief! But how much do I shim it without making the posi way too tight?
Old Feb 24, 2013 | 08:07 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
When you open it up you'll understand it a bit better. You shim each side using the 4 spider gears as a reference for how tight its getting. The goal is to remove all play from the spider gears but not add any preload.
Old Feb 24, 2013 | 09:10 PM
Engine: LB9
Ah gotcha, sounds good. I'll try to crack it open soon enough and we'll see what I'll be looking at! Thanks for the tips guys
Old Feb 25, 2013 | 07:01 AM
big gear head's Avatar
When you put the differentiual back together you will have to stick the axles in both sides to line up the splines before you start to tighten the bolts. If you don't then you will not be able to get the axles in after you put it all back together.
Old Feb 26, 2013 | 09:05 AM
Engine: LB9
Thanks for the tip!
And where can I find bearings for the 9 bolt? I've searched everywhere, but the only source I can find is 9bolt.com; a bearing set shipped from them in Australia is $245! Anything cheaper?
Old Feb 26, 2013 | 09:37 AM
Randy's Ring & Pinion has installation kits and parts for the 9 bolt.
Old Feb 26, 2013 | 12:55 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Also ratechmfg.com has parts. For instructions google this exactly "bw 9-bolt positraction repair". You'll see a pdf at geocities. Print it. It's a great set of instructions with pics and specs. etc.
Old Feb 26, 2013 | 03:11 PM
subroc's Avatar
Engine: 355 TPI
Gotta use that search feature! Here is a thread i did about a year ago when i rebuilt my 9 bolt. If you find the stuff for less your lucky.
https://www.thirdgen.org/forums/tran...urces-9-a.html
Also as noted in that thread...the rebuild kit came with a crappy pinion seal that leaked before it even made it into the car. Autozone has the correct Timken pinion seal.
Also going to add that if you need a hand rebuilding the posi let me know. I rebuilt my posi with new cones and then had a buddy of mine in MA set up the whole rear end with the new bearings.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
