1984 Trans Am Rear Diff upgrade questions
Old Mar 3, 2013 | 03:11 PM
wallyj's Avatar
Car: 84 TransAm
Engine: Vortec 383SBC
Transmission: T56, Stage 2 Ram clutch
Axle/Gears: 7.5 w/28 spline axles and 4.10 LSD
Hello all,
After dropping in my mild 383 last spring I find myself traction deficient
I will be upgrading my rear diff with a posi in the next few weeks, and have done much searching online here with some good info. I have a 3.23 open now, with presumably 26 spline axles.
Question: Can I use used axles out of a never thirdgen to keep costs down on this project, I am limited up here in Ontario on availability of new used, and shipping is prohibitive..
I think Ive settled on an eaton posi, I`ve had powertrax before and it was fine, but it`s not much cheaper anymore, and I have to upgrade axles anyway.
I also have the stock disk with non functioning adjusters I will be rebuilding, any input on those baby`s would be great!
Steve
Old Mar 3, 2013 | 07:23 PM
big gear head's Avatar
Re: 1984 Trans Am Rear Diff upgrade questions
You can use '90 to '92 28 spline axles. The Eaton Posi is a good choice. Also look at the Yukon Dura Grip for a lower cost alternative if money is tight. And get the Yukon super shim set and Timken bearings for the installation.
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 6, 2015 09:03 AM
