T56 Swap Help!
Old Mar 9, 2013 | 05:04 PM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
T56 Swap Help!
Good afternoon people. If anyone can point me in the right direction I would appreciate it. I have searched the threads on here and I am still confused. I need to know what flywheel & clutch setup to use with my swap. I have seen people post the centerforce 700173 or 700107. I also found something on Jegs for a RAM but dont have part number on me currently.
-Pre 86 (2pc seal)
-400 crank external balance - (383 Eagle rotating assembly)
-T56 swap came from 97 camaro
Thanks!
JM
Old Mar 9, 2013 | 05:57 PM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
Re: T56 Swap Help!
I think I found the answer...McLeod Steel Flywheels 460370-3C. Just in case anyone else has this problem.
Old Mar 9, 2013 | 07:00 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: T56 Swap Help!
McLeod 75216-LT1 Super Street Pro Clutch
McLeod 460350-1A-Steel Flywheel LT1
McLeod 8605-Pilot Bearing
Just ordered these today
Old Mar 10, 2013 | 05:54 PM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
Re: T56 Swap Help!
That model number says for a 350. I have a 400 crank so i believe the one I would want is either model 2C or 3C. I am going to call McLeod tomorrow to verify.
Old Mar 10, 2013 | 06:24 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: T56 Swap Help!
Do not "quote" me on this but I think what you need is a 2pc that allows you to bolt a weight to it. That would work with 383/400 etc.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
