Remove " retainer" inside slave cylinder?
Old Mar 10, 2013 | 11:54 AM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Installing all new clutch hydraulics today, along with clutch pedal bushings. Question:
When I take the boot off the slave cylinder there is a little " retainer" inside the slave, does this need to be removed after installation or is it there to keep from "blowing out" the guts of the slave?
My problem is that I am not getting enough pedal to engage clutch. Wondering if any of you that have replaced this part might know the answer...
Thanks.
Old Mar 10, 2013 | 12:28 PM
Re: Remove " retainer" inside slave cylinder?
If you're talking about the thing that looks sort of like a tie-wrap with a little cap in the middle, it's only there for shipping AFAIK; it will burst the first time the pedal is pushed.
The SC should be able to generate several hundred pounds of force, EASILY enough to snap that little nylon band. If it can't manage that, then you have other problems somewhere; air in the system, most likely. The band itself isn't The Problem.
Old Mar 10, 2013 | 12:54 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
leave it on
Old Mar 10, 2013 | 04:49 PM
No, not talkin bout the lil plastic cap thingy, I'm talkin if you actually remove the boot, inside the cylinder there is a lil metal ring snap ring retainer thingy that would keep the guts of the cylinder from falling out.
Guess if no one knows what I'm referring to then its a good sign to leave it in place. Was thinking this might be the reason why I can't get quite enough pedal to engage clutch.
Frozer!!!
Jan 19, 2024 04:55 PM
Glowsock
Aug 26, 2015 12:28 AM
db057
Aug 22, 2015 08:17 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
