problem removing flexplate
Old Mar 10, 2013 | 04:26 PM
arem04667's Avatar
Car: 1987 Camaro Iroc-z
Engine: 305 v8
Transmission: 700/R4
I'm trying to remove my flexplate off my 350 to fix a leaky rear main seal. But i can't seem to get two of the bolts off holding it onto the crank. Ive tried using different breaker bars, wd-40 and impacts with more torque, but they wont budge at all and the bolts are beginning to round off. I think when i installed this flexplate, i didnt torque the bolts properly. (I probably just torqued them all in a circle)
Any suggestion on how to get them off? I was thinking about drilling the bolts out,
Old Mar 10, 2013 | 07:23 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: problem removing flexplate
Use vicegrips on the gear area with the handles against the starter pad to help hold the flexplate from turning the motor.
You can use some valve laping compound on the socket and bolt head for more grip.
Old Mar 11, 2013 | 04:31 PM
pjp209's Avatar
Car: Gone
try too heat them up a little bit then bang them with a hammer.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
3rdgenparts
Aug 8, 2015 07:09 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
