Wont shift past 70
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Wont shift past 70
Hi guys I have a question my 89 trans am tpi 700r4 is not shifting when I have the gas all the way down at around 70 is this normal? when I let off a little it goes to overdrive when I had my camaro 2.8 it seemed the rpm drop was more consistant and it didnt seem to just freeze in the drop down gear. Is it because of the 2.73 gears?
Engine: 4++,350 & 305 CIs
Re: Wont shift past 70
That can be fixed with a few small trans parts.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The main part to fix that is the Transgo 3-4 shift valvetrain. A .500" TV boost valve is a good idea too. Both changes can be made with the transmission in the vehicle.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
